reded Posted October 6, 2004 Report Share Posted October 6, 2004 Is it possible to replace the countershaft seal without splitting the case. My new one leaks and needs replacing. I didn't know since its got the lip that fits into the case. Quote Link to comment Share on other sites More sharing options...
SDD Posted October 6, 2004 Report Share Posted October 6, 2004 I believe that seal does not have a lip on it (better double check first or get a new seal first so you can tell)... pull the sprocket spacer out and that should give you enough room to pull the old one. Make sure that spacer doesn't have a groove or build up on it that will tear up the new seal. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted October 10, 2004 Report Share Posted October 10, 2004 Yea, you can replace that seal very easily. Just screw a drywall or sheet metal screw into the seal, and pop the seal right out. Clean and slide a new one in. Quote Link to comment Share on other sites More sharing options...
racer Posted October 10, 2004 Report Share Posted October 10, 2004 Yea, you can replace that seal very easily. Just screw a drywall or sheet metal screw into the seal, and pop the seal right out. Clean and slide a new one in. awesome, i no longer have to wait to put my cases back together. Quote Link to comment Share on other sites More sharing options...
prichard9966 Posted October 11, 2004 Report Share Posted October 11, 2004 i believe you can change the seal on the flywheel side but the one on the clutch side has a lip all the way around it. it will not pound into the case. my buddy and i just had this problem. he didn't want to pull the motor and split the case to change it. so we took a razor blade and removed the center rib from the seal. you must thoroughly clean the seal cavity with a clean rag and brake cleaner. put a thin layer of silicone on the circumfrence of the seal cavity and seal. install the seal. maybe wipe a little extra on the front once it is in. then let it dry for a minimum of 24 hours. this trick will work but like i said before brake cleaner and a clean rag are your friend. silicone works great but the surfaces have to be perfectly clean. carb cleaner leaves a residue. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted October 11, 2004 Report Share Posted October 11, 2004 Make sure you wipe grease into the inner seal of any seal you put it. Put it on the surface that contacts the moving part. If you look at the seal, it will have a "pit" or "lip" to put the grease into. It will extend the life of the seal tremendously. Quote Link to comment Share on other sites More sharing options...
racer Posted October 11, 2004 Report Share Posted October 11, 2004 Make sure you wipe grease into the inner seal of any seal you put it. Put it on the surface that contacts the moving part. If you look at the seal, it will have a "pit" or "lip" to put the grease into. It will extend the life of the seal tremendously. good tip. Quote Link to comment Share on other sites More sharing options...
