mavguy Posted December 24, 2004 Report Posted December 24, 2004 SWEEEEEET sounds good, i always hated how long it takes a 'shee to rev down. Makes you feel like there's a vacum leak or something. I got a few questions? 1) what do they remove 2) How much mass is removed My dad's freind has a machine shop so im thinking this mod will be worth a case a beer and a few hours work on the lathe, unless its more complex than what i thought? Quote
boonman Posted December 28, 2004 Report Posted December 28, 2004 You remove material from the outside of the flywheel, and some from the center hub. The best way to do it is to have the flywheel mounted on a spindle of some sort, but you could chuck up on the outside. Although it's not the best way to make sure the flywheel is perfectly true....... Quote
