johnautobus Posted October 5, 2004 Report Share Posted October 5, 2004 My stock cdi box went south so I bought a dyna fs box. I installed it and banshee runs. Problem is that motor will not idle and misfires at high rpm. Could the new cdi box be letting the motor rev higher? The directions say to rejet to bigger. I went up three sizes and back to 1 bigger and I still have the misfire at wide open. I borrowed a stock cdi box and it idles good but motor misfires off low rpm. Higher rpm seems better. does any have had experience with changing over to dyna.. What does a person have to do to make motor run right. I think the idea is good to change timing but I am growing tired that banshee would perform. Help would be appreciated. Quote Link to comment Share on other sites More sharing options...
BB3 Posted October 5, 2004 Report Share Posted October 5, 2004 Yeah when i put mine on i had the same problem. Then i adj my idle up a little and put a stock set of plugs back in it , i also set the time curve on #1 and it works get in the dunesnoever jetted up any other than when i put my t-6's on , i turned my idle about 1/2 turn or so. Quote Link to comment Share on other sites More sharing options...
superchicken Posted October 5, 2004 Report Share Posted October 5, 2004 do you have resistor plugs in her?i got my dyna last year,and thought it didnt work.sent it back to dyna,they tested it and said it was fine.i could put my old cdi back on and it would run fine.turns out something was up with my coil,bought a new one and it fired right up with the dyna box?i must say there support staff was the best ive run accross in a long time. Quote Link to comment Share on other sites More sharing options...
