sandoz43 Posted October 6, 2004 Report Share Posted October 6, 2004 Throw 2 qts of oil in the tranny and 2 qts of beer in me after every ride...no problems so far. Quote Link to comment Share on other sites More sharing options...
badassbilletbanshee Posted October 8, 2004 Report Share Posted October 8, 2004 CC's and ml are the same 1500 ml=1500cc=1.5qts not 2. Excessive oil is not a good thing. Quote Link to comment Share on other sites More sharing options...
DIRTBIKEZ Posted October 8, 2004 Report Share Posted October 8, 2004 CC's and ml are the same 1500 ml=1500cc=1.5qts not 2. Excessive oil is not a good thing. Thanks for the info... care to elaborate? Quote Link to comment Share on other sites More sharing options...
azsandrat Posted October 9, 2004 Report Share Posted October 9, 2004 THEY CALL FOR 1.7 I use 2 personally and this is the reason. Has anyone ever had the problem of the clutch rod and ball welding themselves together? I know some have and have seen alot of this first hand. 1.7 doesn't submerge the shaft and ball. 2 qts does and there is no problem running this amount. If you have a modified clutch and use 1.7 chances are it will happen. Usually when drag racing when you have the clutch in and rev it up alot before dumping the clutch. Most shops out west tell you to use 2 qts. I also use a synthetic tranny oil for normal riding. ATF for stirckly drag racing. Quote Link to comment Share on other sites More sharing options...
badassbilletbanshee Posted October 13, 2004 Report Share Posted October 13, 2004 What's to elaborate on meathead? GFY! Quote Link to comment Share on other sites More sharing options...
