bansha60 Posted September 22, 2004 Report Share Posted September 22, 2004 For some reason my right cylinder isnt firing consistanly, it loads up with fuel hardcore, but yet my left side is firing fine, it runs on race fuel and I run Klotz oil. Now, I can only get it to start if I pull start it. It sounds to me like i'm loosing compression, but it dosent lack any power once the cylinder starts to fire right??. Is that what is happening or what? Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted September 22, 2004 Report Share Posted September 22, 2004 Whats your compression in each cylinder?What your jetting info?Are both carbs set the same,and balanced,and are the carbs clean? Quote Link to comment Share on other sites More sharing options...
itsjustagreat1 Posted September 22, 2004 Report Share Posted September 22, 2004 Have you changed your plug....it might be fouled...try new plug caps or first, switch your plug wires to see if it switches the side that doesnt fire. Also if you have a buddy with a shee, borrow his coil and try it. Clean pilot jets. And take your reeds off and clean them. I once had a problem with the oil sticking to my reeds (maxim castor) and it would not run right untill I reved it sky high.. Quote Link to comment Share on other sites More sharing options...
SyNtAxx Posted September 22, 2004 Report Share Posted September 22, 2004 Hey all, I had a similar problem once... It turns out I had a wire rubbing up against my frame and shorting itself out. Once I found the bare wire and taped her up it was good as new. Check all your wires... I belive mine was coming from the stator...but it was a while ago... Nick Quote Link to comment Share on other sites More sharing options...
