bogging and it wont idle any more
stockridinshee
my banshee hasnt been runnin so good lately and i dont know why. iv changed the plugs cleaned the carbs and air filter. it seems liek it wants to bog in the low end a lot. and it wont idle any more either. oh yeah and gas comes out of the over flow for some reason but the floats arnt stuck. i know that when ever gas comes out the over flow that its the floats but why would it just start doing it out of know where? thanks in advance for the help
yep sounds like floats. i you had a drastic temp or elevation change you maybe should check the jetting. but to me it sounds like a plugged pilot or in an extreme case the stator. pull the cover on that one and visually inspect it. you can check them electrically if you know how but i dont.
