engine restorer
that engine restore stuff
Now there is some much needed info... :rolleyes: WTF is it called? Where'd you see it? What is it for?...It sure would be nice to trash a motor...give it some secret juice shizzle & have it fixed just like that, doesn't sound bad, but I just don't see it happen'n. Why do you think you'd need it anyhow? :unsure::confused:
hehe...just rant'n man, get us some more info/detail or you're bound to get all kinds of screwball replies. ;)
Have you ever farted outside when it was really windy & tried to smell it? :unsure:
That would probably yield the same results as the stuff you're talking about...probably not gunna be what you thought. I wouldn't mess with it man, have you ever checked your compression? I see what ya mean after 13yrs & all, but if your compression is low...don't count on a liquid substance 'seen on tv' to fix ya up and cure the problem. ;):cheers:
I does restore some compression. I have used it and tested it in my old pick up. Unfortunately in your banshee youd have to mix it with the GAS for the rings and cylinder to get any effect.......LOL Putting it in the tranny aint going to do shit.....but maybe gum up your clutch plates.
check
On a 2 stroke,probably not.Most definitely on a 4 stroke though,especially on real high mileage engines.I added some to my 95' F250 around 185,000 miles and did notice a little more punch to her.Then again at 255,000 and could definitely notice the difference.
I used to laugh at sjit like that too,but it really does work.They reccommend adding it at every oilchange interval,but that gets too expensive.
Engine restore,Marvel mystery oil and the "fabulous" PB Blaster will always be welcome in my garage.
that shit really does work on cars but i doubt youd find anyway to use it in a 2-stroke. i used it in my old chevelle out of curiousity and did compression testing before and after the lowest cylinder went up 8 lbs. the highest went up 21lbs. it works by having small (were talkin microns) copper particles that fill in scratches and imperfections in the cylinder wall. just my $.02 Ed
