lastlegwarrior Posted September 20, 2004 Report Share Posted September 20, 2004 I was just wondering if i was doing something wrong. My buddy's shee has T-5 pipes, K&N clamp-ons, lightened flywheel, 4 degree advanced timing, and reed spacers. My other buddy's raptor has a fmf powercore slip-on and a K&N replacement filter for his airbox. We raced this weekend and i didn't seem that much faster, also i'm pretty sure my jetting is good. When we would take off we would usually take off out a second (at least that's the gear i took off in) from a rolling start. i figured i would pull pretty good on him, but he usually stayed one or lil'more than one quad length behind me, and then eventually he would catch me on top end and barely pass me (but i expected that because i'm still running stock gearing) Also this was on pavement, so traction wasn't a issue. Basically what i'm wondering is should i have gotten different results, or not? Also i was wondering if maybe i should change the gearing, i mean would that have made the race a little less close? Overall is there anything i can do to make my bud's shee a little more faster than my other bud's raptor? (gearing, different mods, different setups, etc..) thanks for the replies. Quote Link to comment Share on other sites More sharing options...
Mod Banshee Posted September 20, 2004 Report Share Posted September 20, 2004 I would gear it up one tooth in the Front (15/41) and get it Ported and a cool head with 21cc domes and 28mm flat side Carbs and a set of V-Force Delta 2s. Here is the Mod I have on my banshee and I am running 300ft in High 4s FMF Fatty Pipes FMF Power Core 2s Cool head w/21cc domes Race Logic Porting Vitos Power Pistons 28MM Flat side Carbs V-Force Delta 2s Boost Bottle Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Lightened Flywheel Vitos Degree key Pro Flow intake 6 filtered air vents 15/41 gearing And On sunday I Drag raced a Raptor wirh a 686 Big Bore and a Titanium spring kit and Hot cams and a DMC Pipe and K&N Air Filter. and My banshee Killed it with no Problem Quote Link to comment Share on other sites More sharing options...
theeechozen1 Posted September 22, 2004 Report Share Posted September 22, 2004 I can see the rap-turd hangin on hard-pack, but on asphalt I would say put someone on the shee that knows how/when to shift.....keep trying, practice makes you gooder than shyt!!! Quote Link to comment Share on other sites More sharing options...
