canadabanshee Posted September 20, 2004 Report Share Posted September 20, 2004 I just put a 17 front sproket on with a 41 in the rear. It pulls great to fifth. but in 6 it does not go like when i had the stock front sproket on. There is no power band with the 17 sproket in 6 thgear. I dont get it. It goes great up to 6 th gear. It pulls great. when I am in fifth I shift when it sounds good high rpms to. So any clues Quote Link to comment Share on other sites More sharing options...
J.J. Posted September 20, 2004 Report Share Posted September 20, 2004 I just put a 17 front sproket on with a 41 in the rear. It pulls great to fifth. but in 6 it does not go like when i had the stock front sproket on. There is no power band with the 17 sproket in 6 thgear. I dont get it. It goes great up to 6 th gear. It pulls great. when I am in fifth I shift when it sounds good high rpms to. So any clues What don't you get? Your motor obviously doesn't have the balls to pull that kind of gearing. Quote Link to comment Share on other sites More sharing options...
canadabanshee Posted September 20, 2004 Author Report Share Posted September 20, 2004 But it pulls good till that gear. And just crusies in 6 th. I have pro curict pipes, bottle boost,k&n air filter,rtc clutch,jets,and wiseco 30 over pistons. Quote Link to comment Share on other sites More sharing options...
txblueshee Posted September 20, 2004 Report Share Posted September 20, 2004 Do we have to draw you a picture?!??! You're motor doesn't have the balls to pull a 17t.... you need at least some port-work. The boost bottle helps out alot too Mike Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted September 20, 2004 Report Share Posted September 20, 2004 Yeah, throw some reed spacers in just to be safe............. Quote Link to comment Share on other sites More sharing options...
racer Posted September 20, 2004 Report Share Posted September 20, 2004 but did you put the PC stickers on that came with the pipes? that could make all the difference in the world Quote Link to comment Share on other sites More sharing options...
2Smoker Posted September 21, 2004 Report Share Posted September 21, 2004 Pin it in 5th until you got nothing left, then shift into sixth. If your powerband isn't kicking in from a wide open fifth to sixth, your bike doesn't have the testicles for that gearing. Quit living in denial and do something about it. Can you spell S T R O K E R? Quote Link to comment Share on other sites More sharing options...
canadabanshee Posted September 21, 2004 Author Report Share Posted September 21, 2004 Hey guys thanks thats all I am asking for. Its got balls in fifth but not sixth So i know it can not take it. So what gears would be the best. Quote Link to comment Share on other sites More sharing options...
racer Posted September 21, 2004 Report Share Posted September 21, 2004 try like a 15 or 16. Quote Link to comment Share on other sites More sharing options...
sredish Posted September 21, 2004 Report Share Posted September 21, 2004 It pulls great. when I am in fifth I shift when it sounds good high rpms to. So any clues hahahahahahahahah, it's called gearing bro. like smoker said, it ain't got the testes down there to do it. either go to a 42 or 44 rear and try again or go back down to a 16 front. How often are you in 6th anyway. Quote Link to comment Share on other sites More sharing options...
John19 Posted September 21, 2004 Report Share Posted September 21, 2004 It pulls great. when I am in fifth I shift when it sounds good high rpms to. So any clues hahahahahahahahah, it's called gearing bro. like smoker said, it ain't got the testes down there to do it. either go to a 42 or 44 rear and try again or go back down to a 16 front. How often are you in 6th anyway. Exactly what I was thinking Iam at 15 41 for all around riding now. Quote Link to comment Share on other sites More sharing options...
sredish Posted September 21, 2004 Report Share Posted September 21, 2004 I am at 15 41 for all around riding now. I was at 15/41 and the race last weekend was pretty tight and i tried a 15/42 and I notice a wee bit more pull down low and I like this setup a lot. But, I'm forever playing with my setup, so who knows where i'll be next week. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 21, 2004 Report Share Posted September 21, 2004 Do we have to draw you a picture?!??! You're motor doesn't have the balls to pull a 17t.... you need at least some port-work. The boost bottle helps out alot too Mike i bet hes pullin that 17 tooth with his expensive ass screws in there too. your engine aint got nuts huh?? Quote Link to comment Share on other sites More sharing options...
racer Posted September 21, 2004 Report Share Posted September 21, 2004 i bet hes pullin that 17 tooth with his expensive ass screws in there too. your engine aint got nuts huh?? loco i must have read that like nine times before it clicked. thats def the reason he cant run a 17. the studs hook up way better than your screws. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 22, 2004 Report Share Posted September 22, 2004 i bet hes pullin that 17 tooth with his expensive ass screws in there too. your engine aint got nuts huh?? loco i must have read that like nine times before it clicked. thats def the reason he cant run a 17. the studs hook up way better than your screws. yeaaaa. for fuckin 60 bucks for 48 of them they should propell his ass like NOS. Quote Link to comment Share on other sites More sharing options...
