Banshee Gears
Dirpmp2000
change your sprockets-alot depends on your weight and engine modds-try going up on your front-what size are you currently running? Try a 15 on the front-dont listen to PEOPLE-listen to other banshee owners-they are PLENTY of good banshee owners here who can guide you in the RIGHT direction :cheers:
it has 14 teeth i think stock, just check yamaha's website to be sure. for longr gears you can go up one front tooth or down 2-3 on the back. but for bottom end you will need to get lower gear ratio via a smaller front or a larger rear sprocket.
