BansheeBoy17 Posted September 18, 2004 Report Share Posted September 18, 2004 Ok... i went around the local MX track about 8 laps then it jus started bogging after i landed on a jump. I cleaned my carbs, checked the jets, put new plugs in, and cleaned my air filters, and messed with my air screw. ... took it for a test ride and it does the same thing. I can floor it and it runs fine but the second that i let off and try to get back on the throttle it bogs like all hell ? Quote Link to comment Share on other sites More sharing options...
siezed-up Posted September 18, 2004 Report Share Posted September 18, 2004 might be a strech but check your intake manifolds to make sure they didn't crack when you landed. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted September 18, 2004 Report Share Posted September 18, 2004 Checked the reeds? Quote Link to comment Share on other sites More sharing options...
txblueshee Posted September 18, 2004 Report Share Posted September 18, 2004 This may sounds crazy but make sure you're gas tank vent line diddn't get pinched off. Mike Quote Link to comment Share on other sites More sharing options...
J.J. Posted September 19, 2004 Report Share Posted September 19, 2004 Ok... i went around the local MX track about 8 laps then it jus started bogging after i landed on a jump. I cleaned my carbs, checked the jets, put new plugs in, and cleaned my air filters, and messed with my air screw. ... took it for a test ride and it does the same thing. I can floor it and it runs fine but the second that i let off and try to get back on the throttle it bogs like all hell ? Float height? Quote Link to comment Share on other sites More sharing options...
Bansheerider29x Posted September 20, 2004 Report Share Posted September 20, 2004 hate to tell you man but you need to rebuild the whole top end mine had the same problems it would run fine tell i let off thegas then it would bog a lot i rebuilt it and new its fine. just gie it new rings pistons and gaskets Quote Link to comment Share on other sites More sharing options...
racer Posted September 20, 2004 Report Share Posted September 20, 2004 yeah if you dont have cylinder wall damage you can get away with a hone and rings maybe. worth a try. Quote Link to comment Share on other sites More sharing options...
