Stock machine adding FMF Fattys
banshyeeha
Hi guys
I am based in the UK and new to your great forum.
Just had my FMF Fattys and Power Core 2 silencers delivered from the USA - second hand but great condition.
My question is that I would like to fit these tommorow and ride but getting hold of jets in the UK is near impossible, I have some 270's ordered but they haven't arrived yet.
Temperature tommorow will be approx 15 degrees and I have a completely standard 2000 banshee.
Will I be OK to ride my bike tommorow with the standard jets and my new exhaust system or will I blow her up !
When I ride tommorow it would be for say 15 mins and then a break of 15 mins on and off throughout the day, mainly high revving in 2nd and 3rd gears around a small MX track.
Any help would be greatly appreciated.
Thank you in advance.
I wouldn't run it with the Fatties and stock jetting and it wont hit the band and rev well under a load anyway. (starting and adjusting the air screws is ok)
The typical main size that come on a stock banshee are #200s. If you put the pipes on, install the 270 mains, remove the airbox snorkel but leave the air box lid on it should be fine. The stock pilot jets #25's may be a bit small but should work. You will probably want to turn the air screws to within 1 or 1/2 turn of seated (all the way in) to richen up the pilot circut. With small pilots that are running a litle on the lean side, richening the needle (move the clip one or 2 slots away from the blunt end) will help compensate.
