Ahh, back on the warpath
Titanium
So I took it apart and jazz...Here's the Story
Bad Radiator Cap = Ran out of coolant = Not good.
Low Compression on one side (don't know which)
New stator, but started firing weak on the right side, combusted maybe 1/5 times
Replaced Radiator Cap
Replaced Coil, Caps and Wires
Re-Seated and gasketed head, trinity o-rings and RTV
3 studs pulled out of block, one caused small coolant leak
re-studed the leaky one, torqued all but the 2 loose ones
Had to Pull-Start it, when it did the left side (where the 2 loose studs are) fired fine, right side still not combusting 100%
one stud with non-sheathed non-acorn nut leaks coolant out the top of the nut, loose stud next to it leaks out the bottom. the loose one IS a sheathed acorn nut.
Also, when the Right side does fire, it sounds louder and more distinctive (almost like a ping) but that may just be only hearing One fire every once in a while.
Also, I plan on re-threading the studs tomorrow, If they will thread.
Questions...
What would be causing this odd firing? I'm assuming it is a spark problem as the head was JUST re-seated and it's obviously getting fuel, but the coil, caps and wires are new.
What is the best option for tapping the cylinders, if this needs to be done? Will RTV seal the nuts?
Thank you!
ak
you deffanately have a head gasket leak.heli-coil the threads and you should be good to go
