Race Logic templates
Fireman-hott
I used them on my bike and it made a huge difference. I also raised the exhaust port, but I don't remember the measurement. I don't think Dremel makes an attachment that will get to your transfer ports. The most important thing that I can think to tell you is if you haven't done any porting yourself on a Banshee is to watch out for your water jackets.
The templates are real easy to use and you will be amazed by the change.
how does the power come on. what about the bottom end. does it rip your arms off when it grabs the pipe?
My jetting isn't right yet so the low end is a little hesitant but the throttle response is great and when the powerband kicks in you better be holding on tight!!!
I also have my head milled .040, Fatty pipes with K&N pods.
I did all of this at once, so I couldn't tell you the individual gains.
Just order the kit myself hoping to make a good improvment i order a flexable attachment for my dremel tool hoping its works will keep u guys posted hopefullly it works good,( Siezed-up) what size jets did you start with? was thinking of starting with a 330 or 340 and a 30 poilt jet, i will have a 80 over bore and noss cool head with 18cc domes and t-6's and will be running 107 or better fuel. just let me know thanks (BBIII)
Edited by BBIII
I live in Michigan so I'm pretty high above sea level. I have 330's with stock 25 pilots because that was all my local dealer had. I need to up my pilot to 30 or more. Sounds like you've got the right idea, just run it and check your plugs to get it dialed in. I didn't do anything with the transfer ports and the thing still just screams.
