02Shee Posted September 14, 2004 Report Posted September 14, 2004 on ebay there is a set of Works Pro Series Triple Rate Shocks With Piggyback Rezzys With Adjustable Compression and Rebound for 450 bucks is it a good deal jus rebuilt mad for 165lb rider i'm 140 in shorts with gear im figuring 150 about and also it comes wit black shock covers look at them tell me yes or no i told they guy i would buy them to hold on to them jus give me a hour to get ebay setup Thank you Vinny Works Shocks on Ebay Quote
sredish Posted September 14, 2004 Report Posted September 14, 2004 Looks like that's not a bad deal. They'd probably work for you. If you did get them and decided the springs were just a bit stiff, you could always replace the main spring with a slightly softer spring and they'd work perfect, as long as they're in the condition he says they're in. DUNEDEMON here on the BHQ can usually help you with springs also, if you need it. Quote
SDD Posted September 16, 2004 Report Posted September 16, 2004 Adjustable Compression and Rebound Those do not have adjustable rebound. They have adjustable preload and compression dampening. I have the pro series with remote rezzies which do have the adjustable compression and rebound settings. At any rate those are going for a pretty good price as long as the shafts are not pitted. The fully adjustable ones like mine go for around 850 but those are probably 600+ new. Quote
ledofthezep Posted September 16, 2004 Report Posted September 16, 2004 (edited) Not a bad deal at all. Good price for a major improvement over stock. Shoot him an offer for 400 before you do the 'buy it now'...since there are no other bids. Edited September 16, 2004 by ledofthezep Quote
