bick Posted September 14, 2004 Report Share Posted September 14, 2004 filled up three days ago, and its a ll gone, no signs of leaks other than my fuel problem. were could it go. Quote Link to comment Share on other sites More sharing options...
nater006 Posted September 14, 2004 Report Share Posted September 14, 2004 Drain your crankcase oil... see if it comes out all milky or otherwise odd. That might be your antifreeze leak. Unless you have a leaky head gasket and it leaked out during riding, in which case you'd probably see a bit of white smoke during the ride. Quote Link to comment Share on other sites More sharing options...
Holyman Posted September 14, 2004 Report Share Posted September 14, 2004 Did you mess with the coolant bottle or radiator when you filled it up? Quote Link to comment Share on other sites More sharing options...
2Smoker Posted September 16, 2004 Report Share Posted September 16, 2004 filled up three days ago, and its a ll gone, no signs of leaks other than my fuel problem. were could it go. what do you mean it's all gone? All gone out of your resivoir tank AND the rediator? Or just lost it out of the resivoir? If youre burning antifreeze itll smell sweet and there will be white smoke coming form the pipe(s). Check the oil with your dipstick and see if its milky. If none of the above, and it's just the coolant tank, were you pulling wheelies or riding on rough terrain? If I'm going on an all out wheelie tear then I lose alot out of the bottle. Let us know. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted September 16, 2004 Report Share Posted September 16, 2004 If you're not loosing the coolant internally or have a problem with the machine... this will help your problem... http://kuoi.asui.uidaho.edu/~john/tips.html Quote Link to comment Share on other sites More sharing options...
2Smoker Posted September 16, 2004 Report Share Posted September 16, 2004 If you're not loosing the coolant internally or have a problem with the machine... this will help your problem... http://kuoi.asui.uidaho.edu/~john/tips.html hell yeah - I'm going to do that to mine this weekend. Quote Link to comment Share on other sites More sharing options...
bick Posted September 16, 2004 Author Report Share Posted September 16, 2004 no, it just disappers. no smoke while riding, no antifreeze in crankcase Quote Link to comment Share on other sites More sharing options...
2Smoker Posted September 16, 2004 Report Share Posted September 16, 2004 no, it just disappers. no smoke while riding, no antifreeze in crankcase NO IT JUST DISAPPEARS WHAT?!?!?!?!?!?!?!!!?!?! JESUS YOU WANT US TO HELP YOU ANSWER THE QUESTION!!!! what do you mean it's all gone? All gone out of your resivoir tank AND the rediator? Or just lost it out of the resivoir? Quote Link to comment Share on other sites More sharing options...
nater006 Posted September 17, 2004 Report Share Posted September 17, 2004 You've got to have a leak somewhere then, if even a pinhole leak, if the stuff isn't going into your crankcase or burning through the engine. If its a pinhole leak they can be hard to detect. I don't know how it would react to the Shee's cooling system, but there are kits with a dye you can put in and find where it is leaking out. We did that to a buddy's Silverado, and sure enough it had a big dye mark in the middle of the radiator. Never saw it between the clutch fan, etc, but the dye marked the spot. Probably want someone with a little more cooling system experience on the shee to answer whether it is safe or not. I dunno why not but... can't hurt to have second and third opinions. Quote Link to comment Share on other sites More sharing options...
boonman Posted September 17, 2004 Report Share Posted September 17, 2004 (edited) NO IT JUST DISAPPEARS WHAT?!?!?!?!?!?!?!!!?!?! JESUS YOU WANT US TO HELP YOU ANSWER THE QUESTION!!!! Calm down my friend. No need to get all bitter. I realize he hasn't said if it is all gone, or just the rezzy, but dammmmm!! If it's all gone out of the radiator, it is going somewhere. If the exhaust doesn't smell sweet, and there's no smoke, than it is leaking out of somewhere...... If it is gone out of the rezzy, than don't worry. It happens to all shees. Relocate the bottle to the front. It won't happen anymore..... If you determine it's a leak, you need to check, and double check everything. Hoses, connections, gaskets..... I don't think the dye would hurt anything. But you should be able to find it without getting dye..... Edited September 17, 2004 by boonman Quote Link to comment Share on other sites More sharing options...
2Smoker Posted September 19, 2004 Report Share Posted September 19, 2004 I know but he won't say where it's leaking from, and if it's just coming out of the resivoir then it's perfectly normal especially if you're pulling wheelies or something. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted October 11, 2004 Report Share Posted October 11, 2004 Did you ever figure out the mysterious leaking trbl. Quote Link to comment Share on other sites More sharing options...
