kenr74 Posted September 10, 2004 Report Share Posted September 10, 2004 I need to replace one of the studs in my rear hub. Does anybody have some advice on getting the old one out? I was thinking BFH since I don't have a press but maybe there is an easier way. Quote Link to comment Share on other sites More sharing options...
nater006 Posted September 10, 2004 Report Share Posted September 10, 2004 I need to replace one of the studs in my rear hub. Does anybody have some advice on getting the old one out? I was thinking BFH since I don't have a press but maybe there is an easier way. A hammer should work. Best thing to do is support the backside of the hub on some metal pieces or on top of a vice or similar... something with a slit or hole so the stud has room to move backwards out of the hub, but the back of the hub is supported. Quote Link to comment Share on other sites More sharing options...
BenBB Posted September 10, 2004 Report Share Posted September 10, 2004 Yep drive it right out, I think I set mine on a large socket (like a 22mm impact socket) to support the back side of the hub as I was wailin' on it. Quote Link to comment Share on other sites More sharing options...
kenr74 Posted September 10, 2004 Author Report Share Posted September 10, 2004 Ok, that's what I was planning on doing. Just didn't want to find out later that there was an easy way. Thanks guys. Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted September 10, 2004 Report Share Posted September 10, 2004 id heat it up good first to make as easy as it can Quote Link to comment Share on other sites More sharing options...
racer Posted September 10, 2004 Report Share Posted September 10, 2004 open up a vise just larger than the head of the stud then pound away. might put a block of wood over the end of it though so incase it flies out the hammer wont actually hit the hub. Quote Link to comment Share on other sites More sharing options...
