Plug chopping
fernando427
Every thing I have read about plug chopping envolves winding the shee out in 6 gear. Can it be done in any other gear like 2nd? I have t-5s on 03 shee pro flow adapter k&n lid on no snorkel. I am running the tommey specs which is 280 mains and the toomey needles. I run it at el mirage which is about 3000 feet above around 90 deg and also at pismo beach wheres its about 70 deg sea level, but I want to remove my lid. Theres a place by my house where i can run it but not enough room to do a 6 gear chop. Will i just have to do the chop when i go riding? Any help is appreciated.
if its an elevation change thats where id do it.......i like ringing third out but im geared pretty tall, either fresh plugs or look at it, reinstall it, bang it over and dragg it to your prefered high gear, lugging it loads it up, then your buring that off and sometimes it can make it appear rich when really its lean just burning off shit from the pilots, and not having a load on the chassis helps also i.e. shooting comp hill to do a plug chop....
I actually try to use old plugs not new ones. New ones will need to be ran for 15 to 30 minutes pretty hard to start coloring much at all. If you just put them in and go plug chop, they might not have hardly any color, skewing your readings.
yeah you should pound it for a few on those fresh plugs before a chop, or just wire brush yer old set before you chop them...6 of one half dozen the other..... B)
