pipe carbon build-up
Go to the local dollar store and buy two cans of oven cleaner. Preferrably the kind that requires the oven to be hot. The pipes do not need to be hot, that formula just seems to work better. Spray about 1/3 of a can in each pipe and slosh it around in there until you think everything is coated. Let it sit for about 15-20 minutes and then hose it out. Repeat if you feel it's needed. I've used this stuff to clean the worst baked on crap from the insides of silencers and it works great and it's dirt cheap. Even works great on de-greasing parts but it WILL STRIP PAINT if the paint is not powder coated or factory yamaha paint. So be careful. You may want to make sure there is a breeze outside when you do it and DO NOT breathe the fumes or get it on your skin. IT BURNS.
  • 4 weeks later...
