Shee_Man Posted August 29, 2004 Report Share Posted August 29, 2004 whoever had the banshee before me was heman when he tightened these screws Any idea what I can do... I need to rejet. Think they're too small to "easy out" and replace? Quote Link to comment Share on other sites More sharing options...
superchicken Posted August 29, 2004 Report Share Posted August 29, 2004 small pair of vice grips wile you turn the screw driver.give a few wacks first to try to loosen them Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted August 29, 2004 Report Share Posted August 29, 2004 ya what chicken said stick screwdriver in them and wack it with a hammer then try to turn them and then you might order some allen heads off ebay or somewhere so this never happens again Quote Link to comment Share on other sites More sharing options...
Shee_Man Posted August 29, 2004 Author Report Share Posted August 29, 2004 yeah... it's more the stripping that i'm worried about :S... i'm going to wd-40 them up again tomorrow and wack 'em a bit and take my time... try the hammer trick too. Has anyone ever e-z outted these screws before... i've read of a few guys with stripped screws on their carbs, lol... Quote Link to comment Share on other sites More sharing options...
sneeky Posted August 29, 2004 Report Share Posted August 29, 2004 leave the carbs in direct sunlight for an hour or so after you put wd40 on the screws a flameless heat gun works best, just dont have any fuel in them, hold the heat gun way back so you cant light them up and just make them hot enough so that you can still touch them so you dont fry any rubber or plastic bits if you do end up breaking the heads off it is probably a job for your local machine shop to drill them out if you strip the thread in the holes in the carby you can buy a rethreader kit by RECOIL or something similar and drill, tap the holes to suit. DISCLAIMER: thats what i recon, but if you f*ck them dont blame me!! lol Quote Link to comment Share on other sites More sharing options...
philshee Posted August 29, 2004 Report Share Posted August 29, 2004 Try the small {4 inch. ) vice grips. Put the jaws of the vice grips around the head of the screws , clamp down and turn very slowley Quote Link to comment Share on other sites More sharing options...
Killer_Shee Posted August 29, 2004 Report Share Posted August 29, 2004 Take a Dremel or a small die-grinder and cut a slot in the head so that you can use a straight screwdriver to get the screw out. Then take those phillips head screws and throw them as far as you can, and then go to the hardware store and get allen cap screws to replace them. Quote Link to comment Share on other sites More sharing options...
blk02banshee Posted August 29, 2004 Report Share Posted August 29, 2004 Do what killer_shee said! That's the best way to do it. You can also buy a stripped screw extractor kit from sears. You just put it in a reversable drill, and push hard while running the drill slowly in reverse, and it'll come right out. Quote Link to comment Share on other sites More sharing options...
dnhyoung Posted August 29, 2004 Report Share Posted August 29, 2004 the screews on my 04 grizzly carbs were tighter than hell, I wanted to kick some guy on the assembly line in the scrotum for tightening them so tight. I ended up getting a small set of easy-outs at sears, and just back them out and replacing them with some allen head screws. Good luck Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted August 29, 2004 Report Share Posted August 29, 2004 Try the small {4 inch. ) vice grips. Put the jaws of the vice grips around the head of the screws , clamp down and turn very slowley before you do anything drastic try this...this has worked for me every time and doesnt damage the screws at all Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted August 29, 2004 Report Share Posted August 29, 2004 dremel!! then the allen heads like killer-shee said Quote Link to comment Share on other sites More sharing options...
2Smoker Posted August 29, 2004 Report Share Posted August 29, 2004 I had the same problem this weekend on a friend's tri-z and used vice grips loosened the 4 screws no problem! Quote Link to comment Share on other sites More sharing options...
