racer Posted August 26, 2004 Report Share Posted August 26, 2004 when you get a new set of wiseco piston it has a pair of wondows that face the intake side of the motor. but when looking through the jugs and into this window it is smaller than the intake port on the jug itself. so my question is can you safely remove a portion of the aluminum in this area so that the two are perfectly matched in size. if you could im positive it would help air flow by increasing size and reducing drag. of course you have to have both pistons matched but thats not a big issue, just take a few measurements. so what do you guys think? Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted August 26, 2004 Report Share Posted August 26, 2004 ive heard its not worth it, and if you do it with like a dremel you can damage the piston and cause it to crack Quote Link to comment Share on other sites More sharing options...
racer Posted August 26, 2004 Author Report Share Posted August 26, 2004 oo, in that case ill pass on it thanx Quote Link to comment Share on other sites More sharing options...
fixitrod Posted August 26, 2004 Report Share Posted August 26, 2004 It will also "unbalance" the piston, weaken it, make it untrue. Not worth the risk if you ask me either. Quote Link to comment Share on other sites More sharing options...
Hiram Posted August 27, 2004 Report Share Posted August 27, 2004 I did mines, I only cut them wider to match my porting, it's been 6 months and it screaming!!! Quote Link to comment Share on other sites More sharing options...
