yamaholic125 Posted August 25, 2004 Report Share Posted August 25, 2004 are they good on banshees, i wanna know cuz i just ordered one, and also how hard are they to install Quote Link to comment Share on other sites More sharing options...
Banshee17Racing Posted August 25, 2004 Report Share Posted August 25, 2004 I love mine. It's kind of hard to fork out that much money for a lever, but you won't regret it. You will never worry about clutch cables again. Installing it is pretty easy, just be patient when dealing with the cylinder under the carbs. BE careful not to bend anything. And also look out for the hosing rubbing against the pipes(if you have the plastic or rubber hosing). I've heard it's known to melt if it gets too hot. Josh Quote Link to comment Share on other sites More sharing options...
DUNEDEMON Posted August 25, 2004 Report Share Posted August 25, 2004 I have never ran one, but the guy who builds my engines does not like them, says they return too slow. Good luck. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 25, 2004 Report Share Posted August 25, 2004 i had one and i liked it. you never have to adjust it. they are fairly simple to install. youll have to pull the carbs to do it. Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted August 25, 2004 Report Share Posted August 25, 2004 I've had mine for a few years now. Yes the stock plastic hose will melt if it get's too close to the pipes..happened to me. But once you set it up right, you NEVER have to adjust anything until you run the clutch out..then you have to adjust the clutch internaly. The hydraulic cylinder offers LESS resistance then a standard cable setup plus the feel is so much better. You can run heavy duty springs and actuate the lever with one finger. Clutch return speed is in direct porportion to the spring tension on the plates. Quote Link to comment Share on other sites More sharing options...
nater006 Posted August 27, 2004 Report Share Posted August 27, 2004 I didn't spend the $$$ on one because the rod that pulls the clutch lever looked really puny. Just heard some stuff about 'em breaking and bending easy and didn't want to fork out the big bucks for the billet cyl setup. But... if they're working well for people.. great! Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted August 27, 2004 Report Share Posted August 27, 2004 After burning a few hundred dollars on a few diffrent ez pull clutch levers. I decided that the money I'd save in the long run might be worth a gamble at a hydro clutch. I'll never go back to a cable clutch setup. It's that good. Yes those that know..Know. Those that don't know..they don't know..until they do ..they'll never know. Hydro all the way. Quote Link to comment Share on other sites More sharing options...
