Banshee MX Setup
XM-137
Here's my mod list for my MX banshee...pulled off my site; probably left a few out, but owell. :D I'm not done yet...but how can you be? :shootself: And of course, not all of my mods are needed for MX, just picked up along the way. ;)
1997 Yamaha Banshee, full custom gussetted frame
Ported & Polished - mild
Milled Head
Dyno Jet Kit
Hinson Clutch Baskett
Barnett Dirt Digger Clutch
Chrome Pro-Circuit Platinum Pipes & Silencers
+2+1 LoneStar Chrome A-arms
Works Triple Rate Shocks w/Rezzies
-2 Burgard Swingarm w/round house Honda style twin row bearing carrier
Ohlins Rear Shock
+2+2 Durable Eliminator axle w/Honda hubs
Graydon Proline Nerf bars
Toomey 2:1 w/UNI filter & Outerwear
White Bro's Boost Bottle & Break Block-Off
Fly Racing Handlebars w/pro-grips
MSR Raptor Clutch Perch & Lever
TM Design Works Chain Slider
AC-Racing swingarm skid
Outerwear's Shockwears - front & back
Cascade polished grill & 'eye' light covers
Polished gas cap, footpegs, & brake
Edited by ledofthezep
Milled Head
Dyno Jet Kit
Ohlins Rear Shock
Sand poser...
I'd get 2 into 1 intake and pipes, a wider axle and a-arms, shorter swingarm, smaller tires (preferably turf tamers or holeshot mx depending on how loose the dirt is i think the holeshots would be better for looser dirt,) better shocks, and gear it down a little.
Also get a good clutch lever, i have the MSR ez pull shorty lever and it helps a whole lot around corners being able to get the rpms out. Also invest in a cable luber so you can keep your cable from getting shit in it and making it harder to pull. Theres tons of shit you can do for mx if you have the money.
You must be pretty good if your running pro on a stock machine. I assume your running 2 stroke pro open class. Your good unless the other riders suck..or maybe there was only 6 entries in the race..or only 6 in your class and the line was filled with bikes from other classes. The best advise I can give you is don't worry too much about your motor. A set of V-force reeds and good pipes will give you plenty of power. Your best bet would be to upgrade your chassis. They make long travel suspension kits for the banshee now..wishe they made em' when I was building mine up...It should only cost you about 3-4 grand to dump a long trave +3 front end with 21in custom axis shocks with compression and rebound adjusters and a -1 roundhouse style swingarm with another custom axis shock in the rear. The shocks alone will run you over 2100 bones. But they are the best money can buy. Then go out and get a steering damper. You'll thank me later. Don't forget a nice extended axle in the rear to match the width of the front and your tires should be mounted on a set of carbon fiber wheels from hipertech with a 3-1 offset in the front to keep it within the 50 in AMA legal limit.
please show me this in the rule book.............my lobo bike with 4+1 offset was 53 1/4 inches wide...........mx don't matter...................flat track and tt you have to be under 50 inches..........................please show me.
There were 10 in the class but I would say that class was more like a B class but for one rider he was a A class. As for my self I would have to say Iam not to bad for a old guy hehehe.
freddy
http://www.ama-cycle.org/rulebooks/04amrules.pdf
All the way in the back. 50in max width allowed for AMA racing.
C. General Equipment Standards
Equipment used in all sanctioned competition must meet basic
standards, except as otherwise specifically provided for in these
Rules for Competition. Where the rules permit or require
components of equipment to be installed, replaced, altered or
fabricated, it is the sole responsibility of the rider to select
components, materials and/or fabricate the same so that the
ATV components will perform in competition with safety.
1. All ATV
