Maverick302 Posted August 20, 2004 Report Share Posted August 20, 2004 What gearing/tire size should I use for a ~1/4 mile (give or take 200ft)? I was thinking maybe a 17/39 with 20's, I might pin 6th by the finish, but just a bit curious if my motor would pull it, and whether that's a logical setup. Also, any ballpark guesses on what kind of times to expect? Mod's: FMF Fatties Coolhead w/ 20cc's 28mm flatsides Proflow filter Boyesen Carbon reeds/ cages Dirt digger clutch Quote Link to comment Share on other sites More sharing options...
roosthrower Posted August 20, 2004 Report Share Posted August 20, 2004 I honestly don't think that you see 6th gear with a 17 tooth front. I'd go to a 16/41 setup and hope it pulls sixth. Et's will probably be in the 15's. Maybe high 14's if your lucky. Or you could just race 1/8th mile. Banshee's and other quads in general fair much better over shorter distances. Quote Link to comment Share on other sites More sharing options...
NYUK Posted August 20, 2004 Report Share Posted August 20, 2004 What gearing/tire size should I use for a ~1/4 mile (give or take 200ft)? I was thinking maybe a 17/39 with 20's, I might pin 6th by the finish, but just a bit curious if my motor would pull it, and whether that's a logical setup. Also, any ballpark guesses on what kind of times to expect? Mod's: FMF Fatties Coolhead w/ 20cc's 28mm flatsides Proflow filter Boyesen Carbon reeds/ cages Dirt digger clutch gotta have the ponies to pull them big gears maverick. start out a lil smaller. Quote Link to comment Share on other sites More sharing options...
fast frankie Posted August 21, 2004 Report Share Posted August 21, 2004 before I got my motor work done I ran stock banshee tire with 17/39 gearing with pretty much the same settings as you I was going low 16 high 15's and the best way that I found to launch the bike was to just spin the tires out of the hole because like nyuk said it takes a big motor to pull a good tire Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted August 23, 2004 Report Share Posted August 23, 2004 that sounds like a pretty good setup. You may be able to run a little taller rear tire, try the the 20's first though Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted August 23, 2004 Report Share Posted August 23, 2004 i didn't read you mod's closely. i would run no bigger than a 20 in tire. Quote Link to comment Share on other sites More sharing options...
Maverick302 Posted August 26, 2004 Author Report Share Posted August 26, 2004 Ill probably end up with 16 or 17/41 with an 18 incher with shit for traction to spin on asphalt through first to stay in the powerband, and haul ass after that. Quote Link to comment Share on other sites More sharing options...
