4 stroke knowledge required :)
d3xnij
i want to do the daddogriders engine build, it required a 488cc big bore kit and a 5mm longer rod crank, ive got the link to the bigbore kit and im wondering if its the right big bore kit because theres stage 1-4
check it out
very bottom, 490cc kit stage 1 http://www.maxpower-engines.com/bb-yamaha.htm
will this do the trick ?
i forgot to add, it sais i need a lower compression piston to run pump gas, do u know what compression piston i need and where to get 1 ?
any help will be greatly appreciated
thanks
Edited by d3xnij
