turbor Posted August 18, 2004 Report Share Posted August 18, 2004 I just bought my 04 shee and it is hard to start when cold (i do use the choke) like 10-15 kicks, when it is warm, it starts first kick... is that normal? what could cause it? i run 94 octane fuel with klotz oil mixed at 40:1 Quote Link to comment Share on other sites More sharing options...
BansheeJerry Posted August 18, 2004 Report Share Posted August 18, 2004 It should still be under warranty... Take it back to the dealer. No need for you to worry about it. Quote Link to comment Share on other sites More sharing options...
loganskinner Posted August 18, 2004 Report Share Posted August 18, 2004 you cant get a warranty on a yamaha 2 stroke. believe me i tried. hell even the 4 strokes only have the option of i think its a 6 month warranty. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 18, 2004 Report Share Posted August 18, 2004 I had the same problem and I had to go up one size on the pilot jet. I'd give that a shot first before tearing too far into it. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted August 18, 2004 Report Share Posted August 18, 2004 Here what i do... shake gas tank up good and turn gas on ...pull choke all the way out and bump the gas a little and kick it and once it starts push the choke in ..that should do it Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted August 18, 2004 Report Share Posted August 18, 2004 Here what i do... shake gas tank up good and turn gas on ...pull choke all the way out and bump the gas a little and kick it and once it starts push the choke in ..that should do it Quote Link to comment Share on other sites More sharing options...
Gordon's Hell Posted August 18, 2004 Report Share Posted August 18, 2004 Go to the gym Quote Link to comment Share on other sites More sharing options...
philshee Posted August 20, 2004 Report Share Posted August 20, 2004 A suggestion, if your hitting the throttle before you start kicking it, try not to, don't touch the throttle until it fires up. Thats what I do and it starts up on about the 6th kick when it's cold. Quote Link to comment Share on other sites More sharing options...
