Toomey Banshee Posted August 14, 2004 Report Share Posted August 14, 2004 I'm in the process of putting my sons shee back together, just replaced the crank seal and had the top end done and threw new pro lites in. I took the carbs off and cleaned them up real good. Before the rebuild the choke would not stay out, just slid right back in after you pulled it out. Same problem, I took the choke out of the carb, sprayed the crap out of it, still isnt working. Any suggestions? Quote Link to comment Share on other sites More sharing options...
pimp559 Posted August 14, 2004 Report Share Posted August 14, 2004 You need a new choke switch. Yours is worn out. It will probably br cheaper to buy a used set of carbs for the switch than it would to buy the new switch. The switch is the thing you pull out. The rubber pieces on the part that go into the shaft are too small now and let it just slide back in. Quote Link to comment Share on other sites More sharing options...
United Pot Smoker Posted August 15, 2004 Report Share Posted August 15, 2004 you just need a new seal. dont know if they sell just that seal or if you have to but a whole setup though. Quote Link to comment Share on other sites More sharing options...
