xt45 Posted August 11, 2004 Report Share Posted August 11, 2004 Banshee's throttle is too stiff, is there a way to soften it up ? Quote Link to comment Share on other sites More sharing options...
hamuel Posted August 11, 2004 Report Share Posted August 11, 2004 buy pwk 28mm carbs??? 100% lighter and easyer to tune? or cut the springs yah got and then re-length them. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 11, 2004 Report Share Posted August 11, 2004 cut a loop of 2 off the carb spring. i did it with my 35mm carbs and it made a world of difference. its really easy to push now. Quote Link to comment Share on other sites More sharing options...
nickxc Posted August 11, 2004 Report Share Posted August 11, 2004 if you unplug your tors you can take the spring out of the throttle itslelf. There is an extra spring in there just take the throttle cover off and take the nut off the top of the throttle and take off the arms, washers, and spring. put it all back on but the spring... Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted August 11, 2004 Report Share Posted August 11, 2004 Or invest in a 2 into 1 carb that helped a lot for me, it also gives you a lot more low and midrange power. You could also get a new throttle itself. Terry cable makes a sweeet throttle with a longer lever, but its kinda pricey, or you could get a moose throttle extension, i think Cascade inovations also makes one. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted August 11, 2004 Report Share Posted August 11, 2004 I cut 6 coils from each of my 35mm pwk's. Then I just stretched the spring back out. It's fine. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted August 11, 2004 Report Share Posted August 11, 2004 Just quit being a Nancy & build up some endurance! Quote Link to comment Share on other sites More sharing options...
sredish Posted August 11, 2004 Report Share Posted August 11, 2004 Just quit being a Nancy & build up some endurance! Exactly what I was going to say when I saw the title. Nancy, that's funny as foook!! Quote Link to comment Share on other sites More sharing options...
banshee0044 Posted August 11, 2004 Report Share Posted August 11, 2004 Just quit being a Nancy & build up some endurance! yea...i was told the same thing...(dont be a pussy and deal with it)....try squeezing a tennis ball bfore bed...or even better yet Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted August 12, 2004 Report Share Posted August 12, 2004 twist thottle! Quote Link to comment Share on other sites More sharing options...
xt45 Posted August 15, 2004 Author Report Share Posted August 15, 2004 Twister could get you into a dangerous situation, don't use it. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 19, 2004 Report Share Posted August 19, 2004 get some carb tops Quote Link to comment Share on other sites More sharing options...
flea49 Posted August 19, 2004 Report Share Posted August 19, 2004 Most mikuni carbs are stiff,I always cut 4 rings off, Quote Link to comment Share on other sites More sharing options...
checkster Posted August 19, 2004 Report Share Posted August 19, 2004 i used a 400ex throttle and the ergos are much more comfortable. i have noticed i can make alot more laps with the EX throttle before my thumb gets tired......just my .02 tom Quote Link to comment Share on other sites More sharing options...
