jetting Question
Shee_Man
It's a good question to ask! The trick is to use the main jet that is just right for your mods,temp.,and altitude without going too rich or lean.Keeping it rich will gunk up things in your motor.It will also mess up your silencer packing.Thats more oil your shee needs to burn off.You will be fuel starved.
Lean is just asking for trouble.If your lean during the day when the temps outside are 85-90degrees and your evenings are roughly 65-70 your running that much leaner. Lean scares the crap out of most banshee owners.
Try to get as close as possible with the main.
  • 2 weeks later...
