Percy Posted August 8, 2004 Report Share Posted August 8, 2004 My 01 Banshee used to always start 1st or 2nd kick and still does most times, but recently has been battling to start 1 out of 3 times, mainly when warm. It has new plugs and filter is clean. What else should I check for? (When it is doing this it is just dead when I kick it, and then after about 30 kicks it will splurt a bit and then fire up. Normally splutters a bit on start up then 100%.) Other times I just starts 1st kick?? Appreciate any help Percy-Zn Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted August 8, 2004 Report Share Posted August 8, 2004 how old is the fuel, clean the carbs and reeds, also do a compression test and get back with the results Quote Link to comment Share on other sites More sharing options...
Hockey390 Posted August 8, 2004 Report Share Posted August 8, 2004 this may not be in, but it could give you some ideas. When your jetting is off, sometimes a warm engine will show symtoms more then a cold engine. Hence, if your engine starts fine when cold, and has trouble when warm, your jetting may be off. Check what fro said, then if that all checks out, see if your jetting is good. Quote Link to comment Share on other sites More sharing options...
Percy Posted August 14, 2004 Author Report Share Posted August 14, 2004 Hi Guys, thanks for the replies. The shop took the top end off for me and it's a mess inside. A ring has broken! (Why?) and all chaos in there. The shop are saying I must have a new top end and also advise I do the bottom end at the same time, or the new top end may put more pressure on the slightly worn bottom end and break the whole lot again. Do you guys I agree I need to do all this? The piston is already max oversize, so barrels need to be resleeved as well. All in all very costly repair.... Appreciate any advice Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted August 14, 2004 Report Share Posted August 14, 2004 well since ur on the last bore you can go 2 diffrent ways. you can either get 2 new jugs for around 3-400, or a big bore kit which'll be about the same Quote Link to comment Share on other sites More sharing options...
wv banshee Posted August 17, 2004 Report Share Posted August 17, 2004 u be better off to get set of juggs of e-bay and hve bore to accept stok style piston if you ride hard on thing with shee you get wisco piston u may get more hp but as alwals more hp means more work lol thats why i alwals have 2 back up top ends i got one .040 and one thats is 414 in stock cylinders bouth new in grage u learn to have spare top end i did know were a .040 tope end is for 300.0 i think it may need bored if inthersted i could call and see what least he take for it i sold him a lasleeve 409 power valve kit and i think he got a .020 top end with pistons for around 450 thats new with out gaskets hope this help u Quote Link to comment Share on other sites More sharing options...
