bansheeigo Posted August 8, 2004 Report Share Posted August 8, 2004 I want to buy a compression tester for my shee,whats the best one out there? Thanks for your replies. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted August 8, 2004 Report Share Posted August 8, 2004 I was told that the Snap-On tester was the best and only one to use. It's the only Snap-On tool I have, and it wasn't cheap. Works great, I used a cheap Craftsman tester before buying the Snap-On and it doesn't show the same results. Don't know if there are others of the same quality or not, but I wanted to know for sure my exact compression. Quote Link to comment Share on other sites More sharing options...
Wassup350 Posted August 8, 2004 Report Share Posted August 8, 2004 I have a Craftsman compression tester and it works fine. From what i understand is that as long as you can figure out the compression on both cylinders all you need to know is if there is a difference in compression or not to see if you need a top end rebuild. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted August 8, 2004 Report Share Posted August 8, 2004 how much are they?are the metric? oh yea thats a slick shee Quote Link to comment Share on other sites More sharing options...
bansheeryder_69 Posted August 8, 2004 Report Share Posted August 8, 2004 Yeah how much is a compression checker and would checker sell them? Quote Link to comment Share on other sites More sharing options...
svtkid78 Posted August 8, 2004 Report Share Posted August 8, 2004 I have both a snap on and a craftsman and i get the same readings on both. As for the question on (Are they metric?) they read in psi's. If you are talking about the threads for the spark plug holes, dont worry about it the kit you buy will have one to fit your hole. make sure you use one with the same length thread as your plug so the piston doesn't make contact with it. May sound stupid, but i've seen it happen. Quote Link to comment Share on other sites More sharing options...
dogboystoy Posted August 9, 2004 Report Share Posted August 9, 2004 I have seen 2 kinds, one (like I have) screws into your spark plug hole (the best kind, IMO), The other hast a rubber end and you hold it onto the sparkplug hole, pushing on it to make a seal. But that takes 2 people on a banshee. The one I bought from napa cost me appx 40$, works great. has a long lead hose to move the guage to a spot so you can see it. The kit also came with an adapter so that it can screw into 3-4 different size holes. I noticed that it doesnt work with a Yamaha Warrior because the sparkplug hole is too small for the tester. But, it works great for the banshee. Quote Link to comment Share on other sites More sharing options...
Stuff Posted August 9, 2004 Report Share Posted August 9, 2004 I use a Craftsman compression tester and compared the results with two other Snap-On testers and they all read the same. Quote Link to comment Share on other sites More sharing options...
BansheeJerry Posted August 10, 2004 Report Share Posted August 10, 2004 I have a mac tester and I love it. May not be as expensive as snap-on but it is just as good. Quote Link to comment Share on other sites More sharing options...
