Keihen 33 flat slides
Now its missing in the middle and not ideling without bliping the throttle. Needle adjustment after the V-Force? Different pilot? I have 160 mains in them now and its 80-90 degrees at sea level. When I put the V-Force in my 99, I didnt have to mess with the needle at all.
The reeds will affect the pilot and needle circuit the most. You have to play around w/ them. If your shee seems to like the air screw .5 turn out from seated, then try a larger pilot, if the air screw likes to be 2.5 turns out from seated then try a smaller pilot...once you get the idle down, then try leaning out the needles one clip.
What more can I add? Reeds will change things a little.
