DirtRider Posted August 6, 2004 Report Share Posted August 6, 2004 stock timing, stock head, makuni 25-26 mm carbs. its got no air box mods the snorkle is still on. white brothers air filter. its got fmf fatties and pwer core 2 silencers. and 64.25mm bore. 500 above sea level. anyone know what pilot jet i should run? it has 30's and ran with it, but im not sure if there the right ones. anyone know? any one know wha pilots come with those pipes? Quote Link to comment Share on other sites More sharing options...
sredish Posted August 6, 2004 Report Share Posted August 6, 2004 We really can't tell you what pilots. If I had to guess, I'd say 27.5 would be all you need and maybe the 25 with the snorkel still on, but the only person who can know that is the rider. If it's not fouling or sputtering off idle, and your off idle responce is good, then just go with it, if it starts sputtering or cutting out some, then you might go down one size. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted August 6, 2004 Report Share Posted August 6, 2004 I had fattys with the airbox lid off and stock carbs. It like the stock 25 pilots the best. You may have to play around with them to find out. Quote Link to comment Share on other sites More sharing options...
9603banshee Posted August 8, 2004 Report Share Posted August 8, 2004 For FMF's the 25 should be allright unless it starts a little hard, then go with 27.5. You shouldn't need 30's though. Quote Link to comment Share on other sites More sharing options...
gurny Posted August 8, 2004 Report Share Posted August 8, 2004 Why do you still have the snorkel on???? If you have a air filter and pipes your suposed to take that off let your shee breath alittle better. Try that out if anything drop down to 27.5. Don t forget to check your main jets after removing the snorkel, but you should be ok maybe up a size or two!!! Quote Link to comment Share on other sites More sharing options...
Banchetta Posted August 8, 2004 Report Share Posted August 8, 2004 Everybody hit this right on the nose....like gurny said. Take the snorkel off!!! Your losing some serious hp....I'd even cut the last 1.5" off the end of the air box lid right behind the clips so you still have all 4 clips holding it on. Quote Link to comment Share on other sites More sharing options...
