degree key?
ness
I am going to have one of the members here lighten my flywheel. I have to order a flywheel puller, and was wondering if a +4 degree key was worth getting while I'm ordering the puller. My question, if installed properly will the degree key stay put? What are the possible negative affects of advancing the timing by 4 degrees? Last, I'm running Mr Noss' head with 21cc domes on an otherwise stock motor.
You can mod your stock plate to allow +4 degrees of advance for no money at all. just slot the hole to the left so you can rotate the stock plate clockwise. 1mm = 1 degree, so you'd want to make the slot long enough to allow your plate to turn 4mm.
Easy enough, as far as the flywheel, great mod, i've got and i like it. pm boonman and he'll give you a very sweet deal.
later.
