Carb Sync
I have a pair of long legged inside calipers at home, with the filter removed, I stick the calipers inside the carb to measure the height of the slides... Easier than the window method.
Just look into the slides from the rear. Check them at full throttle or when they line up with the top of the opening of the carb. The slides should be flush with the top of the carb opening at the same time. If not, adjust one or the other. Then, adjust the idle screws, if you have them, so they lift off at the same time. This way they are in synch the whole time.
yOU CAN STICK TWO SAME DIAMETER DRILL BIT IN YOUR CARBS AND ADJUST YOUR SLIDES TILL THEY ARE BOTH RESTING ON THE DRILL BITS.
Excellent idea :clap:
My single syncs right up, no probs.
A ladies man as well as a smart-ass :P
