Oilsmoke Posted August 1, 2004 Report Share Posted August 1, 2004 OK First Off No Smart SOB'in answers. OK what are the differences between 85/86 models & the 87/92 model besides the graphics. Quote Link to comment Share on other sites More sharing options...
zilladude Posted August 1, 2004 Report Share Posted August 1, 2004 85-86 had a piston port w/reed assist motor, no exh. power valve, 5spd, shorter front shocks, round rear bearing carrier & 4 bolt rear hubs. 87 was the first year of the full cylinder reed/power valve motor, 6 spd, 87only 8 petal reed, has longer front shocks, 1st year of the p.i.t.a rear chain adjustment, 5stud rear hubs. 88-90 got a different cylinder with a smaller 6 petal reed cage 91-92 have a new rear suspension design. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted August 1, 2004 Author Report Share Posted August 1, 2004 Thx ZIllaDude I was hoping you reply. My Son quad is a 86 and runs damm good. Was only on it's 2nd set of tires from being new, But the front brake calipiers are different colors one is purple & other aluiminum. the reason i state this was becuase the front right tire had too much chamber and the top of the tire was leaning out about a half inch, Didn't notice it until we cut the plastic. Well I was wondering if the that right side Aarm got change along the way with a new design. Possible? Quote Link to comment Share on other sites More sharing options...
zilladude Posted August 1, 2004 Report Share Posted August 1, 2004 Do you have any pics of it from the front? Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted August 1, 2004 Author Report Share Posted August 1, 2004 No pic's Sorry. Quote Link to comment Share on other sites More sharing options...
zilladude Posted August 1, 2004 Report Share Posted August 1, 2004 Measure the a-arms from the ball joint to the frame on both sides, if they are the same length check the steering knuckles to see if they are bent. I have found out the hard way that the knuckles will bend before the a-arms. If eveything is ok you might have a tweaked frame. Quote Link to comment Share on other sites More sharing options...
