racer Posted July 31, 2004 Report Share Posted July 31, 2004 so whats the trick to puttin those damn o-rings on? im having trouble with the two that actaully go on the domes and the two that seal the head to the jugs. im using grease to hold them in the cutouts while i put it on but should i be using something else? any help is appreciated Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted July 31, 2004 Report Share Posted July 31, 2004 grease should hold them in no problem. I don't understand the problem you are having? Quote Link to comment Share on other sites More sharing options...
racer Posted July 31, 2004 Author Report Share Posted July 31, 2004 they fall out of the grooves and get all cut when i torque the head all the way down. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted July 31, 2004 Report Share Posted July 31, 2004 If you grease them up right they won't fall out. Unless you and fighting the head to get it down on the cyclinders. Quote Link to comment Share on other sites More sharing options...
racer Posted July 31, 2004 Author Report Share Posted July 31, 2004 shit, i msure thats it. i been kinda having to hit it a little with my palm to get it to seat correctly and i bet that is knocking those things ouf of place. ok so how do you all do it. do you put the domes on the jugs then put the oter piece on, or do you put the domes into the head and seat it all at the same time? Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted July 31, 2004 Report Share Posted July 31, 2004 I work the base plate and dome first than install the top. Gently is the key word. Quote Link to comment Share on other sites More sharing options...
racer Posted July 31, 2004 Author Report Share Posted July 31, 2004 ok so i thought i had it fixed, but no. just roasted my topend and im on the last bore. who's got the number of a good sleave guy? Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted July 31, 2004 Report Share Posted July 31, 2004 I would Look up Jim Smart Of Passion Racing Engines if I live in OK. Passion Racing Engines Tulsa, Oklahoma Telephone: (918)272-5665 or (918)232-3950 email: passionre@cox.net Quote Link to comment Share on other sites More sharing options...
racer Posted August 2, 2004 Author Report Share Posted August 2, 2004 hell yes, i live in OK. ok guys what are the pros and cons of a big bore motor? gimme all i need to know cause theres no reason to not do it from what i can see. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted August 5, 2004 Report Share Posted August 5, 2004 Thats easy question, None And Not enough money. Quote Link to comment Share on other sites More sharing options...
racer Posted August 5, 2004 Author Report Share Posted August 5, 2004 Thats easy question, None And Not enough money. thats really not so true. jim at passion told me that hed had very bad luck with the only two hed ever done. ended up ruining both stes of cylinders and he had to pay for it. and since when i get my money laid out right hes going to be doing the portwork, i think ive decided against them. everyone told me there was way more power to get out of porting than big bore. plus i wont have to change my domes. Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted August 5, 2004 Report Share Posted August 5, 2004 Yes I was wrong. I was thinking Stroker when I answered the last question. I have learned that Big boring a stock cylinders Is not as favorable Because the transfer tracks are to small to help the big bore make added power. But if you go with aftermarket cylinders than is all changes for the better. Dollar for dollar it hard to beat what you get with a Long rod stroker. This is my opinion. Are there any others? Quote Link to comment Share on other sites More sharing options...
