beatmiester Posted July 23, 2004 Report Share Posted July 23, 2004 what else should i do when i"m in there? i have a mega flow impeller,bearing,seal gasket for water pump cover,new driver gear and knock out pin do i need a side cover gasket? i'm going to use wetter water and anti freeze and yama lube 10w 30 4 stoke oil in the trans 2 times it over heated on me in some hard riding in the sand the quad is a 01 and it is all stock stock pipes,airfilter,and jetting so i dont think its a lean issue plus the oem water pumps do go bad from what i understand Thanks for the input Quote Link to comment Share on other sites More sharing options...
racer Posted July 23, 2004 Report Share Posted July 23, 2004 (edited) ditch the watter wetter and get some engine, really great shit. did you replace the gear with a plastic factory one or did you find a billet one somewhere, if you got a billet one post the site cause i want one. o and you can reuse your side case gasket if its not torn, some get one try before they tear it but ive taken mine off like 4 times and its still good. Edited July 23, 2004 by therail Quote Link to comment Share on other sites More sharing options...
beatmiester Posted July 23, 2004 Author Report Share Posted July 23, 2004 is there a o-ring that needs to be replaced near the rad hose and case? also i never heard of a billet gear i was just going to get a yamaha one Quote Link to comment Share on other sites More sharing options...
troyminator Posted July 24, 2004 Report Share Posted July 24, 2004 I just did my pump/gear/seals. I also put the plastic one in. I didn't get a new e-ring, because they didn't have them in stock...but mine looked ok anyhow. Piece o'cake. Just be careful when installing the new bearing back in...don't let it get cock-eyed. Also, make sure you pay attention to the direction that the seal goes in. Good Luck, T Quote Link to comment Share on other sites More sharing options...
Lepew Posted July 24, 2004 Report Share Posted July 24, 2004 I assume your trying to solve a overheating issue. It seemed I always overheated when I rode hard at the dunes. I tried everything, new waterpump, head gasket, jetting, water wetter and finally I got the solution. I purchased a quality temperture gauge from ESR after seeing one on a freinds 250r. It is money well spent. On stale days or riding with the wind you don't get enough air thru the radiator, or when your ripping hill climb after hill climb. Coolheads, oversized radiators, aftermarket impellers, coolant additives all probably help try to cool it faster but a gauge will tell you when your banshee needs a break to cool down, perferrably pointed in the wind. Quote Link to comment Share on other sites More sharing options...
sredish Posted July 24, 2004 Report Share Posted July 24, 2004 also i never heard of a billet gear i was just going to get a yamaha one don't get a yamaha piece of plastic shit. get a pro design aluminum impeller off of ebay and make sure it never melts/breaks. also, use engine ice not watter wetter. watter wetter is good for 5 or 10 degrees straight, mixed it ain't shit, and engine ice is used straight and is good for 50 degrees. Pro Design Banshee Impeller Quote Link to comment Share on other sites More sharing options...
sandman121383 Posted July 26, 2004 Report Share Posted July 26, 2004 anybody run engine ice in their big trucks or sports/race cars? just been wondering it Quote Link to comment Share on other sites More sharing options...
knight_ripper Posted July 26, 2004 Report Share Posted July 26, 2004 Yes replace that O-Ring. Mine went bad after replacing the kicker gear. I had coolant spewing all over my boot and pipes in high gear only...... It was weird....didnt leak when idleing or in low gears .... but the second I went WOT.....the shit was spraying everywhere..... What I did to fix it....cause I didnt know where it was coming from...in this order.... Hoses.... clamps.... radiator.... O-Ring..... Quote Link to comment Share on other sites More sharing options...
