richybanshee Posted December 14, 2004 Report Share Posted December 14, 2004 My 2 cents... Check this info on reeds at http://www.wickedatv.com/duportal30/home/d...hannel=Products Quote Link to comment Share on other sites More sharing options...
ikikazz Posted December 15, 2004 Report Share Posted December 15, 2004 i put the 3's on they BLEW BALLS so my dealer called them and they said that they are having a problems with the 3's and sent me a set of 2's. Quote Link to comment Share on other sites More sharing options...
1sreamin350 Posted December 20, 2004 Report Share Posted December 20, 2004 My 2 cents...Check this info on reeds at http://www.wickedatv.com/duportal30/home/d...hannel=Products 293024[/snapback] looks like the g3's flow alot of air! I've tried to look for the g3's on the web, not to many advertisments. Quote Link to comment Share on other sites More sharing options...
Klotzban1 Posted December 20, 2004 Report Share Posted December 20, 2004 i put the 3's on they BLEW BALLS so my dealer called them and they said that they are having a problems with the 3's and sent me a set of 2's. 293313[/snapback] ikikazz? What is that in your avatar your holding in front of your mouth? Quote Link to comment Share on other sites More sharing options...
canyncarvr Posted January 15, 2005 Report Share Posted January 15, 2005 (edited) re: i put the 3's on they BLEW BALLS so... So....how is it that the manufacturer of the DF3 hasn't even started making them yet? And you got yours last month? Do you see anything odd with that timeframe? I just talked to them (Mototassinari) two weeks ago. They said at that time they were about two weeks out from their first production run. The DFII and DF3 are hugely different. The II is a screw-together cage with adjustable tension stops. The 3 is a snap fit cage, no adjustable tension stops and an 'air former' that is reminiscent of the rad valve. I've run both the II and the 3 on my dirtbike. The DF3 is hugely better. Of course, that doesn't have any bearing necessarily on what they do on a banshee. My DF3s are 'on order' @ Rockymtn. ***edit*** 2/16/05 Called RockyMtn: On backorder. Edited February 16, 2005 by canyncarvr Quote Link to comment Share on other sites More sharing options...
