Klotzban1 Posted July 19, 2004 Report Posted July 19, 2004 Has everyone heard of the BOSS Intake setup for the Banshee? Its said to have a built in equilizer tube and you dont have to use a balance tube or boost bottle. Quote
PlaynSand Posted July 19, 2004 Report Posted July 19, 2004 I have one , pretty slick one piece billet intake and the cross over is built inside so the intake is over an inch thick, got mine from http://www.passionracingengines.com/ Someone else should chime in , I think nearly all of the Passion engines are using this intake. Quote
locogato11283 Posted July 19, 2004 Report Posted July 19, 2004 I have one , pretty slick one piece billet intake and the cross over is built inside so the intake is over an inch thick, got mine from http://www.passionracingengines.com/ Someone else should chime in , I think nearly all of the Passion engines are using this intake. fuckin right. i have one. its sick. looks real nice and it helps you to clear the clutch arm with big carbs. i highly recommend it. get ahold of jim at passion. Quote
cjm02ram Posted July 19, 2004 Report Posted July 19, 2004 I have on also...Very trick!!! Highly recomend it Quote
Klotzban1 Posted July 19, 2004 Author Report Posted July 19, 2004 My is stock with power add ons like my sig says. Would my non- built motor benifit from this Boss setup? If so,...I'm on my way to getting this Boss setup!! Quote
locogato11283 Posted July 20, 2004 Report Posted July 20, 2004 My is stock with power add ons like my sig says. Would my non- built motor benifit from this Boss setup? If so,...I'm on my way to getting this Boss setup!! i dont know if youll really benefit with it right now since you are not really built. but if you do plan on building it up then yes youd be better off with it. you plan on gettin crazy with your engine? Quote
The Rebel Posted July 20, 2004 Report Posted July 20, 2004 I've looked at that intake, and it is a good looking piece. I'm still running stock carbs so I didn't pop for it. The equalizer tube is built into the manifold so there is no clutter on the outside of the unit. Would work good with 35 air strikers. Hey loco what is your 12 port set up for, is it all drag or can you still play on it. What is the compression psi. I noticed your running +4 on the timing. Quote
KMAC Posted July 21, 2004 Report Posted July 21, 2004 For sure the BOSS is a good add on, built or not, talk about a precision machined bad ass billet intake. I love mine. Quote
chipdog Posted July 21, 2004 Report Posted July 21, 2004 I have one , pretty slick one piece billet intake and the cross over is built inside so the intake is over an inch thick, got mine from http://www.passionracingengines.com/ Someone else should chime in , I think nearly all of the Passion engines are using this intake. fuckin right. i have one. its sick. looks real nice and it helps you to clear the clutch arm with big carbs. i highly recommend it. get ahold of jim at passion. is there any way you can post a pic . Quote
Klotzban1 Posted July 21, 2004 Author Report Posted July 21, 2004 When putting the Boss intake on...Is there a gasket? Quote
PlaynSand Posted July 22, 2004 Report Posted July 22, 2004 When putting the Boss intake on...Is there a gasket? Yes , you just use stock reed gaskets. Quote
PlaynSand Posted July 22, 2004 Report Posted July 22, 2004 I have one , pretty slick one piece billet intake and the cross over is built inside so the intake is over an inch thick, got mine from http://www.passionracingengines.com/ Someone else should chime in , I think nearly all of the Passion engines are using this intake. fuckin right. i have one. its sick. looks real nice and it helps you to clear the clutch arm with big carbs. i highly recommend it. get ahold of jim at passion. is there any way you can post a pic . Here's a pic Quote
jscharphorn Posted February 3, 2013 Report Posted February 3, 2013 I just snatched one of these off ebay, seeing this is a real old post is it still a good product and is stock reed gaskets still recomended ? I found these gaskets on ebay will these work ? http://www.ebay.com/itm/YAMAHA-BANSHEE-REED-GASKETS-SET-OF-FOUR-/290857439270?pt=Motors_ATV_Parts_Accessories&hash=item43b8745026&vxp=mtr Quote
Nightmare Posted February 3, 2013 Report Posted February 3, 2013 I run boss intakes on all three of my bikes. Yes u can use stock gaskets but I would new ones. Sent from my SGH-T679 using Tapatalk 2 Quote
jscharphorn Posted February 3, 2013 Report Posted February 3, 2013 Thanks, I am going to pick up a v force 4 reed set and I am not going to install the intake until then so I do not need any gaskets becasuse the reed assembly will have what I need right ? Quote
