back fire?
that is deffinately the problem because i was jsut talking to my friend who i bought gas for at the same gas staion and he rund 50-50 gas-vp mix and he said his bike is running like shit but it will still run cuz he has the vp so im so glad i figured out the problem :headbang:
PlUmP :cheers:
Well if you have a parking brake block off kit you should be okay but heres what could be wrong.1.Your whole parking brake electrical assembly could be messed up.2.The thing that the brake cable slipped into might not be pushed back into the slot which pushes a button in there and connects it.But like I said if you have a block off kit thats prolly not it.If not you could zip tie it back,weld it,or cut the two wires going to it and tie them together but dont do this unless you think it will work but im pretty sure when that button in there is pressed thats what it does is complete the circuit in those wires,
Hopefully I helped ya out if not keep tryin man if it will start cant be too much wrong with it.(hope so)
GOOD LUCK
