T5 mounting bracket question
One of the mounting brackets for my T5 pipes is coming apart. The little rubber damper in the middle of the two triangle-like bracket pieces is tearing. Is there a good repair for these at all, or is it basically just buy new brackets? Didn't see them readily for sale on their site, so perhaps it is something available elsewhere... and maybe with a better design. :D Any info/brands/links/etc are appreciated.. thanks!
Edited by nater006
You mean the pipe hanger??
Yeah there are better designs out there, like mine for example.
I put 2 springs in the middle to give dampening qualities and flexibility, and you'll never have to replace anything, and they won't tear or fall apart in the middle of nowhere.
Happens all the time.
after it breaks in two, you can overlap the pieces of rubber and screw a new screw through the rubber and all just above (or below) where it cracked. It'll hold for a long time or at least until you get new ones
Edited by J-Madd
