Extended A-arms what length shock do I need
so can you use stock shocks with +2+1 arms?
Yes..... But everytime your front tires get more than 1ft. off the ground your bumper is going to become a plow when you land. Any aftermarket shock will work but they have to be valved for the +2+1 a-arms.... which does not change the length of the shock.
Mike
TX is on the right track here, what he did not mention is that in addition to the internall valving of the shocks, the spring rate of the spring(s) must also be increased, this is where options like dual / triple rates and zero pre-load stuff comes into play. Bottom line is that stock shocks will fit with standard 2+1 a-arms but they will not be capable of controling the increased leverage placed on them, thus producing a VERY soft front end.
