DirtRider Posted July 5, 2004 Report Share Posted July 5, 2004 i was taking a close look at the pistons to see if i could see a number on them but didnt see any. what i did find is that both pistons move side to side a little bit. is this normL? is it possable i can just get new rings to fit the cylinder instead of boring it out and stuff? Quote Link to comment Share on other sites More sharing options...
banshee04le Posted July 5, 2004 Report Share Posted July 5, 2004 Yeah a good amount of side to side slide is normal on the piston pin but there should be zero wobble or play. It should be a tight slide, just how I like it. If the piston is not burnt or scored on the skirt and the bore is measured to be within spec tolerance for the piston then you can run a hone through the cylinder and throw on a new set of rings. Wrong forum section by the way. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 5, 2004 Report Share Posted July 5, 2004 youd be a lot better off not doing a halfass rebuild job. just have it bored to the next size up and do it right. Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted July 5, 2004 Report Share Posted July 5, 2004 youd be a lot better off not doing a halfass rebuild job. just have it bored to the next size up and do it right. yep, get it done right.. It will pay off in the end! Quote Link to comment Share on other sites More sharing options...
