Holding it flat On MASSIVE hill climbs MASSIVE
TORS bascially consists of 4 switches.
One is on the parking brake lever
One is on the thumb throttle
One on each carb
Basically they are ignition interrupt switches. If the thumb throttle switch gets connected (it makes contact when released) and one of the carb switches don't connect it chops the ignition. It really has nothing to do with how long you hold it wide open. It has everything to do if your carbs STICK open, and you release the thumb throttle.
mine likes to not make my bike idle and down low it is real choppy, and then I'll hit a bump and it'll go back to running smoothly, and then I'll hit a bump further down the road and it'll be back to choppiness and not idling......That little black box has to goooooooo
