HEEEEEEELLLLLLLLPPPPPPPPP
Ok whats the reason you took the carb off in the first place? Did it run well before you did that? What made you think you needed to take it off and clean it and not the other? Its starting to sound like you got water in both carbs, thats why it will try to run when you pour gas down the spark plug hole. Take both carbs off and turn them sideways until no more gas comes out of them. When doing this turn them on both sides to be sure there is not one drop coming out of either carb. I'd tell you to take the bowels off but I'm afraid you might mess something up more. If there is water in those carbs in the bowles it will never start until the water is out. Banshees run on gas not water you silly rabbit. :D
1) You have spark.
2) If you have made sure the pipes are clear, you have exhaust.
3) AIR - Make sure its getting air, take the filter off while your trying to start.
4) GAS - This is MORE then likely your problem...
Usually with carbs, if they are clogged, dirty, have water in them, anything other then nice clean carbs with good flow of gasoline, they will cause you problems.
SOLUTION
I would remove both carbs, and take them apart.. DO NOT clean with a moist rag, DO NOT get water in them...
If you have an air compressor, use that, and some paper towels or other dry rag to clean them. When cleaning, make sure you clear out the main jet completly. I usually either blow through every hole there is, or just make sure I can see through the main. I take my air compressor and just blow air through the gas connection, and the main, and then take the bottom off the carbs and blow pretty much every area to dry it out... Now, whipe them all out, making sure the needle is spotless.. If you get any dirt on the needle in this process, you will notice rapid loss of fuel via the hoses running from the carbs. You can clean the main better if you remove it, so I would take a wrench and unscrew that, whipe out the washer that it sits on, and make sure you can see through the main. Assemble the carbs, I would do them 1 at a time so no parts get mixed... After reassembly, push your thumb throttle in (or twist) to make sure the slides move freely, and make sure they come down all the way so there is very little if any gap at the bottom.
DONT use any quick start fluid.. I dont know if you tried that or not, but its not good for it, so dont.
Make sure all of your connections are good, and make sure there is gas flowing into the carbs. I would unhook the hoses from each carb and turn the gas on and off real quick to ensure it is flowing to each carb properly. Once this is done, make sure your choke tube is on there, and be sure your carb tops are screwed on tight. After this is done, give her a go.. If you do all of that you should be golden. If not, we can further our investigation..
:cheers:
