badlarry Posted June 30, 2004 Report Share Posted June 30, 2004 My shee dies when i get one of the conections from the cdi wet i have limited this to one set of wires. I had siliconed them and it made it worse. I wrapped them all in baloons and zip tied the end tight to seal them but they weather and fall apart after a couple of months, and it looks ghetto. I always could get a new harness from my dealer but there must be a tricker looking more functional trend out there???? help as i just got the bitch running again and it is very wet up in new hampshire where i abuse........i mean ride it. thanks Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted June 30, 2004 Report Share Posted June 30, 2004 wat about good ol electic tape Quote Link to comment Share on other sites More sharing options...
Banshee169 Posted June 30, 2004 Report Share Posted June 30, 2004 You could use split loom and some electric tape. This will give it a much cleaner look than just taping the wires. I did it to mine and it looks smooth! Quote Link to comment Share on other sites More sharing options...
racer Posted June 30, 2004 Report Share Posted June 30, 2004 get shrink wrap from like pep boys or sumthin. its for wires and it comes in various sizes. you just slide it over the wires/ connection then heat it to shrink it and that should help a lot. Quote Link to comment Share on other sites More sharing options...
evil Posted July 1, 2004 Report Share Posted July 1, 2004 are you planing on building a submashee ? Quote Link to comment Share on other sites More sharing options...
racer Posted July 1, 2004 Report Share Posted July 1, 2004 are you planing on building a submashee ? all you need is 200ft snorkel! and some scuba gear Quote Link to comment Share on other sites More sharing options...
evil Posted July 1, 2004 Report Share Posted July 1, 2004 and a "boost bottle" Quote Link to comment Share on other sites More sharing options...
87sheerips Posted July 1, 2004 Report Share Posted July 1, 2004 Qestion on shrink wrap, can u shrink it with a hair dryer?? Quote Link to comment Share on other sites More sharing options...
stogy3 Posted July 1, 2004 Report Share Posted July 1, 2004 Hey badlarry where ya from in NH. I just started riding again in NH and always lookin for a good place to go. Quote Link to comment Share on other sites More sharing options...
badlarry Posted July 1, 2004 Author Report Share Posted July 1, 2004 I live in Massachusetts. I ride at the hopkington everett reservoir usually but sometime goe to freemont. There is not much legal riding here so I still do the covert ops in Wilmington, MA at a local sand pit. Just watch out for john law thats all. I'm 31 years old and can't afford to be caught again on the streets/ ril road tracks etc. Quote Link to comment Share on other sites More sharing options...
evil Posted July 2, 2004 Report Share Posted July 2, 2004 Qestion on shrink wrap, can u shrink it with a hair dryer?? ive seen some work on a hair dryer on high but the thicker black tubing needs more heat then a hd will deliver, ended up using a bic lighter. Quote Link to comment Share on other sites More sharing options...
streetshee Posted July 19, 2004 Report Share Posted July 19, 2004 are you planing on building a submashee ? we at work build complete wireing looms for all our street regd quads that we sell,the best stuff tu use is heat shrink,and this selfwelding tape,its a rubber streatchy tape a bit like electrical tape but thicker and rubber,the total advantage is that i welds itsself together and does not come apart like electrical tape,after a few hours if its been tightly streatched on,there aint no way water can come in and the only way to get it off is to cut it off,im just puttin a new wireing loom on mine now cos the original is shit!!! realy highly recomend this tape,forget electrical tape its not ment for water and dirt and bike cleaner and oil ect,,any electrican should know what u mean if u ask em,if they dont then there a cowboy! Quote Link to comment Share on other sites More sharing options...
bradrs Posted July 19, 2004 Report Share Posted July 19, 2004 The self welding tape is also called cold shrink tape. It is WAY better than electrical tape. It's almost as good as heat shrink tubing, and easier to install without having to cut wires, since you just wrap it. You can pick it up at http://www.waytekwire.com/ among other places. If you go with heat shrink tubing, get the polyolefin lined(sometimes called adhesived lined) tubing. When it shrinks downs, an inner lining melts, and makes an even stronger and more water resistant seal. I think waytek has that too. I used the heat shrink usually, but if I am working in a harness where I can't easily slide the tubing over the wire, the cold shrink tape is my next choice. It has held up pretty well the times I have used it. Good Luck, Brad Electronics Engineer Dynatek Quote Link to comment Share on other sites More sharing options...
streetshee Posted July 19, 2004 Report Share Posted July 19, 2004 well done dr watson! thats it,good one, i swear by it. Quote Link to comment Share on other sites More sharing options...
Dark Ranger Posted July 20, 2004 Report Share Posted July 20, 2004 My Banshee used to die every time I hit a big puddle or got a good soaking some other way. Fried a CDI from it once. I finally got sick of having to dodge every puddle on the trail and decided to check the wiring. I pulled the whole wiring harness off. Some of the wrap looked bad so I decided to pull it all apart and inspect then re-wrap it. When I got it apart I found a few place where the insulation was rubbed off. I shrink wrapped all those places then I removed the crappy connectors they used to hold the wire together and soldered it. I then used silicon on the connections and then shrinked wrap on that. When all done I wrapped the whole thing. Now I could drive it through a lake without it shorting out. A lot of work, but well worth it. Quote Link to comment Share on other sites More sharing options...
