bansheechef00 Posted June 28, 2004 Report Share Posted June 28, 2004 HEY GUYS MAYBE YOU CAN HELP ME OUT I WAS RIDING YESTERDAY AND NOTICED SOME PLAY IN MY REAR END SO I JACKED HER UP AND SHOOK HER ASS AROUND A BIT I NOTICED SOME BIG TIME PLAY WHERE THE SWING ARM GOES INTO THE FRAME RIGHT WHERE THE CHAIN ROLLER IS IS IT BUSHINGS I NEED TO REPLACE ? AND CAN I STILL RIDE OR WILL I HAVE PROBLEMS THANX GUYS FOR HELPING Quote Link to comment Share on other sites More sharing options...
SANDSTAR Posted June 28, 2004 Report Share Posted June 28, 2004 Try tightining the swinarm bolt. Quote Link to comment Share on other sites More sharing options...
Nighty Posted June 28, 2004 Report Share Posted June 28, 2004 bearings out? Quote Link to comment Share on other sites More sharing options...
bansheechef00 Posted June 28, 2004 Author Report Share Posted June 28, 2004 DO THEY HAVE A TENDENCY OF COMING LOOSE Quote Link to comment Share on other sites More sharing options...
DirtRider Posted June 28, 2004 Report Share Posted June 28, 2004 YES TIGHEN YOU SWING ARM BOLT AND IF THAT DONT DO IT REPLACE THE BEARINGS!!!! Quote Link to comment Share on other sites More sharing options...
coolhead03 Posted June 28, 2004 Report Share Posted June 28, 2004 If you end up replacing the the swingarm bearings you might consider replacing the roller with a chain slider Quote Link to comment Share on other sites More sharing options...
Holyman Posted June 28, 2004 Report Share Posted June 28, 2004 HEY GUYS MAYBE YOU CAN HELP ME OUT I WAS RIDING YESTERDAY AND NOTICED SOME PLAY IN MY REAR END SO I JACKED HER UP AND SHOOK HER ASS AROUND A BIT I NOTICED SOME BIG TIME PLAY WHERE THE SWING ARM GOES INTO THE FRAME RIGHT WHERE THE CHAIN ROLLER IS IS IT BUSHINGS I NEED TO REPLACE ? AND CAN I STILL RIDE OR WILL I HAVE PROBLEMS THANX GUYS FOR HELPING Your bearings are most likely bad. DO NOT ride with te bearings like that. You have a much higher chance of tossing the chain and then you will have HUGE problems. Take the swingarm off and look at the bearings and the sleeve that the bearings ride on. Let me know what you find and I can hook you up with the bearings if that's what you need. IHRbearings@peoplepc.com Quote Link to comment Share on other sites More sharing options...
bansheechef00 Posted July 1, 2004 Author Report Share Posted July 1, 2004 thanx holyman as soon as i pull her apart ill contact you Quote Link to comment Share on other sites More sharing options...
