Works shocks
ness
Yesterday I ordered some Works dual rate shocks. I had two options to choose from. 1. shock set up for 150 - 190 pound rider, and 2. shock set up for 200-250 pound rider. I ordered the 200-250 pound set up. I weigh 185, and the bike has a 5.5 fuel tank. Do you think I got the right shocks? Anyone know what makes the difference between the two set ups? Thanks
Works only has a limited number of spring rates they use, yours will be fine, a huge change from stock, you would only notice the difference between the ones you ordered and the others if you rode them back to back.
Great thanks for the reassurance. I was a bit concerned that they might be a little stiff, and no adjustment available. I hope they are a noticable amount better than stock. By the way I found out you can bend the stocks ones.
Been there myself manny years ago, check your a-arm bushings, if you bent a stocker chances are your bushings are history (mine were when I bent my stockers).
Dunedemon, yup it wasn't only the shock that bent (shock, wheel, upper a-arm.) Oh well now I'll have new front rims with Razar 2's, and new shocks. Somehow the lower a-arm, and everything else (including the BFR) seems to have survived.
