Shee is not getting gas to right side
Sounds like a plugged main almost. Either way, some carb cleaning is probably in order. I've seen ones that haven't been cleaned or get crap in them and the needle valve won't even more than a fraction of what it should to keep the bowl full of fuel.
Here's a couple things to check; float level on the left carb, reeds, swap the coil wires and see if the problem follows the wires, pull the coil and have a shop bench test it, and finally check the compression on both sides. You have unplugged the TORS control box, right? Good luck.
